With the SINAMICS S210 next generation servo drive system, comprising a digitally native drive with wide range of corresponding motors and gearboxes, Siemens brings a new level of high-dynamic, motion control in mid-range operation to stand-alone and multi-axis machines. This next generation servo drive system introduces a new level of safety and security to discontinuous motion control in the mid-range segment, as well as moving, processing and positioning functions on a wide assortment of packaging, printing, labeling, pick-and-place, stacking, assembly, chip sorting and filling machines, with a special emphasis on food-and-beverage and pharmaceutical applications, owing to the availability of stainless-steel motor and planetary gearbox options.
The new AT20-600 series of Motorized Vertical Lift Stages from Optimal Engineering Systems, Inc. (OES) features a vertical lift of 600 mm. The AT20-600-01 (pictured) is driven by a Two-Phase Stepper Motor features a repeatability of 5 microns, positional accuracy of 20 microns and has a knob on the motor for manual adjustment.
The new production plant is officially in operation after its formal unveiling at Lafert’s 60th anniversary celebrations in San Donà di Piave, Italy, close to the historic headquarters.
Moticont has released the miniature GVCM-016-019-01M Linear Voice Coil Servomotor. Smaller in diameter than a U.S. Dime this 15.9 mm (0.625 in.) diameter servomotor, also called an electric cylinder, features a high force-to-size ratio of 1.5 N (5.3 oz) continuous force and 4.6 N (16.6 oz) of peak force
The following article looks at the latest news on servo motors, drives and motors. How do we differentiate between the definitions? What can design engineers find between a stepper and a servo motor? Also, a quick update this summer on the benefits of closed-loop motor control.
A quick search of the patents issued, as well as a review of recent articles, shows a wide range of what authors call “servo stepper motors,” “closed-loop step motors,” “hybrid servo motors” and the like. Although the names may sound similar, the performance can vary quite substantially. Most of the “closed-loop stepper motors” are not actually servo motors!
Mitsubishi Electric Automation, Inc. has introduced Economy Solutions, packaged servo and motion bundles that allow for high precision motion control in a way that is quick and affordable to integrate.
Moticont has added a 0.750 in. (19.1 mm) diameter (smaller than a U.S. quarter) Linear Voice Coil Motor, to their expanding line of voice coil or moving coil motors.
