Freudenberg Sealing Technologies can now validate the superior performance capabilities of the intelligent seals it has under development. In addition to their core function, these seals can handle tasks such as sensor applications and monitoring their own state of wear. As a result, they enhance the reliability of machines and systems they help power by providing data about their state of performance and safety. That in turn helps eliminate mechanical failures and unanticipated downtime. A new feasibility study, conducted by Freudenberg Sealing Technologies, has verified the benefits of these sealing functions.
Heidenhain will be exhibiting at ATX West, Booth #4455, on February 7-9 in Anaheim, CA. Heidenhain will showcase the latest in absolute modular rotary encoders. ATX West focuses on how to better automate manufacturing processes by showcasing the latest automation and intelligent robotic technology to increase efficiency and reduce time, waste, and cost.
Binder USA has developed a complete portfolio of connectors, contacts, tools and accessories for crimp termination. Binder’s crimp variants simplify wiring for quick cable assembly on site.
Opto Diode Corporation, an ITW company, introduces the AXUV100G, a 100 mm x 100 mm active area electron detection device specially designed for use in radiation detection applications.
