a successful business.
Tapered roller bearings can be set at initial machine assembly to any desired axial or radial clearance. This unique feature enables a designer to control bearings to meet anticipated application operating conditions, and thereby provide
optimum bearing and system performance.
EDITORS’ NOTE: “The Applications of Bevel Gears” is the excerpted third chapter of Dr. Hermann Stadtfeld’s latest book — Gleason Bevel Gear Technology (The Gleason Works,
Rochester, New York, USA; All rights reserved. 2014; ISBN 978-0-615-96492-8.), which appears here unabridged through the kind graces of Dr. Stadtfeld and Gleason Corp. Future installments will appear exclusively in Power Transmission Engineering
and Gear Technology magazine over the next 12 to
18 months.
