TPS, still organized by the Turbomachinery Laboratory at Texas A&M University, will gather for the 52nd Turbomachinery and 39th Turbo annual event from September 26–28, at the George R. Brown Convention Center in Houston.
The Transfluid MPD (multiple pump drive) is an innovative split drive module designed to sandwich between the main diesel engine and transmission. It features an integrated flexible coupling on the input side and an SAE standard flywheel and housing on the output side. Gear driven PTO heads provide multiple pump pads for mounting pumps, while the output flywheel ensures adequate power transfer to drive larger transmissions.
Bonfiglioli has announced the successful testing and validation of its highly advanced kit of products designed for battery-powered mini excavators. Following rigorous evaluations by multiple original equipment manufacturers (OEMs) across all continents, the results demonstrate an extraordinary improvement in energy efficiency, surpassing industry standards by at least 20 percent.
Sulzer’s OEM-X line service proves instrumental for Indian power plant
July 10, 2023
When older equipment starts to affect the output from the power plant – operators need to act fast, to avoid production risks escalating. This is especially true for legacy pumps. However, sourcing new units to fit the surrounding infrastructure and application requirements of the plant can be challenging. When a major thermal power plant in Rajasthan, India, faced multiple issues with an aging boiler infeed pump, the energy player overcame supply and technical challenges through their partnership with Sulzer. Sulzer provided a custom solution under its OEM-X line service, that cushioned the impact to production, while offering the assurance of reliable associated support, spanning maintenance and spares for decades to come.
The 2023 EASA Convention, June 25-27, at the Gaylord National Resort & Convention Center in National Harbor, MD. EASA (https://easa.com/convention) supports companies involved in the service and sale of electric motors, pumps, drives, controls, gearboxes and other rotating machinery. Highlights include synchronous motors, machine reliability, leadership, sustainability, EASA's 90th birthday bash, motor maintenance, pump repair, supply chain issues and more.
Brazil’s largest producer of ethanol from sugarcane waste is embarking on a major wave of investment. With plans to build 20 second-generation processing facilities over the next seven years, Raízen has picked Sulzer as a key technology supplier.
AD and The Baron Group, a buying group serving independent groundwater systems distributors, announced March 31, 2023, an intent to merge the two organizations. The merger is expected to close on June 30, 2023.
Pumping systems are responsible for over 20 percent of the world’s electrical energy demand, and in some industrial plant operations, they can account for up to 90 percent of energy usage. Improving the energy efficiency of pumping and mixing systems is crucial in reducing production costs and supporting a more sustainable future. Several options can be available and with energy prices reaching new heights, the return on investment is rapidly reducing.
Sulzer and Siemens Large Drives Applications (LDA) are using their collective expertise to provide operators of large centrifugal pumps with an enhanced digital value proposition: Bringing together their respective IoT-platforms and services, Blue Box and Sidrive IQ, the two companies are collaborating to deliver an integrated solution that improves equipment reliability and cuts operations costs.
