Incorporating electromagnetic clutches into industrial applications brings numerous advantages for enhancing system reliability, functionality, and safety. KEB’s Combinorm power on clutches provide a critical solution by ensuring parts of a machine can engage and disengage as needed, particularly in emergencies.
Ruland has released mountable shaft collars with face holes for applications where the shaft collar needs to be directly mounted to a component such as a pulley, sprocket, or metallic plate. The shaft collars are available with drilled face holes that give the user flexibility in mounting hardware, or tapped holes that match the standard screw threading of the collar for ease of installation.
A new line of belts and accessories for industrial and automotive markets
October 5, 2022
JKF Americas Inc, a subsidiary of JK Fenner (India) Ltd., has introduced their extensive Top Drive line of power transmission products to the North, Central and South American markets. The launch of the Top Drive brand is especially timely for businesses that have seen delays and shortages in the supply chain, within the context of the emerging sourcing model across the world.
Navigating Clutch/Brake Operation
in Harsh Environmental Conditions: Chemicals, saltwater, food particles, heat, dust, and electrical corrosion are just a few of the many issues that can
cause clutches and brakes to fail prematurely.
Autonomous vehicles (AVs), in particular, are set to utilize sensors for a multiple array of new technologies. In fact, lidar sensors may be the key to unlocking the potential of driverless cars in the future.
