Emerson has announced its new Branson GLX-1 Laser Welder, which offers users flexibility to meet the growing demand for joining small, complex or delicate plastic components and assemblies. Its small footprint and modular design make it compatible for use in ISO-8 cleanroom environments, while an integral automation controller simplifies installation and interfaces with production robotics.
Igus announces its new iglide i230 3D printing material for selective laser sintering (SLS). This new powder material can withstand temperatures up to 110°C, expanding the use cases for SLS-printed polymer components.
Steel, iron, and aluminum are the dominant materials in the mechanical power transmission industry for good reason: high power density requires the high strength and stiffness of metallic materials. Plastics, however, offer valuable features that should be utilized for good gearbox design.
Global market intelligence firm Interact Analysis recently made some revisions to its global manufacturing outlook forecast. According to the company’s latest research, the outlook for global manufacturing is bleak, and this looks set to continue throughout 2024 into early 2025. Europe in particular is feeling the pinch, while the Americas region fared well during the first half of 2023. Due to the semiconductor slump, manufacturing output in the Asia Pacific region is declining – the region accounts for almost 90% of semiconductor and components production.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
Gears and gear racks used for transmitting torque and forces within gearboxes are typically made of hardened steel. For many other uses and applications, gears and racks made from plastic are the better choice. These generally require no lubrication and are lighter, quieter, less expensive, and more resistant to corrosion than metal gears. This is why JW Winco is expanding its range with polyamide gears and racks that can transmit high forces and torques.
Igus is expanding through investments in its Low-Cost Automation and has now acquired the majority shares in Commonplace Robotics based in Bissendorf near Osnabrück. As an integrator, Commonplace Robotics specializes in intuitive control systems and software and power electronics for robotics, both in industry and in education. The two companies have been cooperating intensively for six years. They have, among other things, developed the igus Robot Control, which supplements igus’ low-cost kinematics made from high-performance plastics.
When it comes to a steel-gear mesh, there are several common standards and design rules on how to reduce noise emissions in the mesh. But if plastic gears are involved, this is no longer the case. The topic of this presentation is to highlight
some of the differences between metal-and-plastic gear meshes, i.e. which design strategies can be stated as valid for metal as well as plastic and which are not?
Microgears for some types of medical technology need to be inexpensively mass produced. But at the same time, they need to be both precise and reliable, even though their design lifetime is relatively short. Here's how microgears were developed for blood glucose measuring devices, insulin pumps for diabetics and other very small devices.
