Are you looking for one simple formula to help you choose between centralized and decentralized motor control? Unfortunately, such a formula does not exist. However, evaluating the overall size of the system, comparing labor and material costs, and maintaining flexibility can help guide engineers in the right direction.
The transverse flux permanent magnet motor -- also known as a hybrid step motor or hybrid servo motor -- has a wide range of performances, depending upon how you drive these motors, and whether you operate them in open loop or one of the many variants of closed loop methods you use. In this third installment we will cover some of the many ways to drive these motors, as well as how these choices affect the performance of these motors.
Many industrial facilities with air-cooled heat exchangers (ACHE) and cooling towers often have older units installed. Depending on the age, repairs, and maintenance done over the years it may have had an impact on performance. Upon conducting site inspections of the equipment, it is sometimes found that ACHE or
cooling tower components have degraded. This can result in a system that is not very energy-efficient and delivers substandard cooling performance.
