ABB recently announced it has completed its acquisition of the Siemens low voltage NEMA motor business. The transaction was originally announced August 11, 2022, and financial terms of the transaction were not disclosed. The business employs around 600 people and generated revenues of approximately $63 million in 2021.
AD Bearings & Power Transmission hosted its 2023 North American Meeting from March 21 to 24 in San Diego, where divisional members and suppliers connected for best practice sharing and meeting sessions dedicated to growing their business.
Optimal Engineering Systems, Inc. (OES) has added four goniometers to their expanding catalog of high precision positioning stages. The new, AK160-30 Goniometer Series feature precision ground worm gears with a 400:1 ratio and pre-loaded cross roller guides offer +/- 30 degrees of travel with 30 kg of load.
Portescap announces the release of the 45ECF brushless DC flat slotted motor, the latest addition to join our flat motor portfolio. The 45ECF features a performance optimized design that utilizes an outer rotor configuration with an overall diameter of 43.2 mm and a body length of only 22.5 mm. The motor features hall sensors to easily control speed and torque and can be provided sensorless based on application requirements. Additionally, the motor can be used in combination with existing gearbox designs to provide high output torque at required operational speeds.
Liebherr expands the existing product portfolio of open circuit pumps by the nominal size of 550 and as a double pump by the nominal size of 1,100 cc (1,100 cm3). Moreover, the new nominal size of 100 adds to the LH30VO family.
Leveraging Dana’s field-proven powershift technology, the eSP502 e-Transmission offers a dual-motor, two-speed design that is built on a flexible platform to enable optimized performance at maximum efficiency in a compact package. The modular approach to the transmission design allows for a single motor solution, as well as an optional power take-off, depending on the specific vehicle requirements. It recently made its North American debut at IFPE 2023.
Hägglunds hydraulic drive systems are a familiar presence in the mining and mineral processing industries, as well as in related materials handling applications. Compact, gearless and utterly reliable, they offer significant advantages over their electromechanical counterparts. Those advantages continue to grow stronger, and the range of possibilities they create is set to expand.
