DC motors possess linear relationships that allow for very predictable operation. For instance, if enough voltage is applied across the terminals of a DC motor, the output shaft will spin at a rate proportional to that applied voltage. You can take the ratio of the applied voltage over the rated voltage and multiply that number by the no load speed and get the running speed.
V-belts look like relatively benign and simple pieces of equipment. They're basically a glorified rubber band, right? Need a replacement? Just measure the top width and circumference, find another belt with the same dimensions, and slap it on the drive. There's only one problem: that approach is about as wrong as you can get.
Over the past several months, members of
our staff have traveled quite a bit, and we've had a lot of opportunities to gauge their confidence. And while nobody
is overwhelmingly enthusiastic - nobody has told us this is their best year ever - almost everyone seems at least content with the stability that slow and steady
growth provides.
In the process of applying industrial drive products, we occasionally are misled into believing that we are applying horsepower. The real driving force is not horsepower - it is torque. This paper is developed to impart a deeper understanding of torque, its relationship to horsepower, and the types of loads we most frequently encounter.
