Offering a track with stronger magnets for their linear motors than previously available, ETEL introduces the new MWD+. This magnet-track family is compatible with any existing LMG and LMS linear motor from ETEL, enabling up to 15 percent higher continuous and peak forces compared to the existing MWD product.
The Electrical Apparatus Service Association (EASA) announces its Spring 2023 training seminar schedule. Offered in various locations around the United States, EASA's industry-specific training pools more than 100 years of rotating equipment knowledge from EASA's technical support staff. Participants have an opportunity to interact face-to-face with the presenters, as well as each other.
IKO International Partners with AutomationWare for Distribution
December 6, 2022
Gear units, motors, and variable frequency drives work in unison to transport items quickly and safely across all intralogistics and warehouse operations
December 2, 2022
With over 200 years of combined experience, Interact Analysis is the market intelligence authority for global supply chain automation. Our research covers the entire automation value chain – from the technology used to automate factory production, through inventory storage and distribution channels, to the transportation of the finished goods. The world’s leading companies trust us to surface robust insights and opportunities for technology-driven growth.
This Oriental Motor article provides more information on these types of noises and what can be done to minimize the noise. It's important to remember to isolate the motor from any other noise-making source, such as metal plates or loose bolts. It's also very useful to have an extra motor in good working condition for noise comparison, so you have a reference point.
