The miniature GVCM-019-032-02 Linear Voice Coil Servo Motor has been released by Moticont. It is only three-quarters of an inch (19.0 mm) in diameter and features a 0.875 in. (22.2 mm) stroke. Also called an electric cylinder, this miniature linear servomotor, features a continuous high-force-to-size ratio of 7.4 ounces (2.1 N) and 23.3 ounces (6.5 N) of peak force at a 10 percent duty cycle.
Engineered with precision and versatility in mind, the MTB 105 is specifically designed to integrate into multi-axis medium- to large-sized Cartesian Gantry systems, providing robust support for medium to high payloads. Its fully enclosed design ensures reliability even in contaminant-prone environments, making it an ideal choice for a wide range of applications. Precision extrusions for each aluminum actuator body ensure all sides and bottom surfaces are flat and perpendicular giving accurate installations.
Thomson Industries, Inc. has announced the availability of new German-engineered precision ball screw sizes with US-based distribution and machining that provide best-in-class load capacity in a small footprint. The Thomson miniature metric ball screw line uses a unique multi-start ball return design that maximizes support for higher loads. This design provides precise, smooth and quiet operation for applications requiring high precision and load handling in confined spaces.
When an application calls for synchronous lifting and pushing of a heavy load, rack and pinion jacks are an easy-to-use, economical and effective option. They combine a simple structure, robust design and a wide range of lifting forces, making them highly versatile and particularly attractive for installation in tight spaces and harsh environments. In fact, rack jacks can be installed as a complete system with many configurations, connected to air cylinders and motors, to guide forces to wherever they are needed in complex applications.
The ATR-V-60-60 Series (-01 thru -04) of Dual-axis Elevator-Rotary Stages has been released by Optimal Engineering Systems, Inc. (OES). These compact, Elevator-Rotary Stages feature a high stability Elevator Stage with 120 mm x 80 mm table and 60 mm +/- 2 mm of vertical travel and a load capacity of 5.0 kg. A 60 mm diameter Rotary Stages is mounted vertically. The scissor lift design of the elevator stages combined with precision roller bearings and slide rails assures smooth motion and very high parallelism throughout the travel of the table. The rotary stages capable of continuous rotation feature high precision bearings and 90:1 worm gear.
This Intellidrives waterproof and dust-resistant linear slide motion axis is engineered for reliability in harsh environments. With IP43 ratings, it withstands water and dust ingress, ensuring seamless operation in wet or dusty conditions. Ideal for outdoor use, marine applications, or industrial settings prone to moisture and debris. These axes offer precise and smooth linear motion control, enhancing automation systems' performance.
Festo introduces its newest generation of Cartesian-handling-system mechanical axes. The ELGD-TB, tooth belt actuators, and ELGD-BS, ball screw actuators, are based on an innovative Festo design.
