End users and OEMs frequently specify
"lubed-for-life" mounted bearings, thinking the lubed-for-life bearings will deliver the same life — without lubrication — as bearings that
currently require periodic lubrication. The truth is it depends on many factors, and only a detailed review of the application and testing will provide a more accurate answer.
a successful business.
