The Society of Tribologists and Lubrication Engineers (STLE) – the premier technical society serving the needs of the tribology and lubrication engineering field – is pleased to announce the release of its 2023 Report on Emerging Issues and Trends in Tribology and Lubrication Engineering. The key conclusion from the 56-page report is that the application of existing and novel tribology approaches has the potential to significantly reduce greenhouse gas emissions and, as a consequence, play a prominent role in helping organizations implement sustainability practices and achieve climate change mitigation goals.
A discussion of the evolution of condition
monitoring for bearings and the upcoming
introduction of company's next-generation
condition monitoring platform.
Whether you design, build or maintain industrial equipment, it is likely you have encountered many types of bearing grease over the years. Lubrication plays a crucial role in virtually all operations, and certain key characteristics allow grease to perform its job better in demanding applications.
For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
