During the past 10 years, the PM industry has put a lot of focus on how to make powder metal gears for automotive transmissions a reality. To reach this goal, several hurdles had to be overcome, such as fatigue data generation on gears, verification of calculation methods, production technology, materials development, heat treatment recipes, design development, and cost studies.
All of these advancements will be discussed, and a number of vehicles with powder metal gears in their
transmissions will be presented. How the transmissions have been redesigned in order to achieve the required stress levels while minimizing weight and inertia, thus increasing efficiency, will also be discussed.
One of our goals at Power Transmission Engineering is to help you understand, identify and select the best technology for your mechanical power transmission or motion control applications. With every project, you have to decide which components to use, and which suppliers, based on functionality, quality and price. We aim to help you make those decisions informed by providing the latest information on current technology, especially when it comes to mechanical components.
