The following article explains the commonly used paint components and methods within the gearmotor industry, with a focus on electrodeposition coating (E-Coat). These processes will be described in general, with a closer examination of the E-Coat applications steps. Some pros and cons of each method will be presented along with comparative test results showing the benefits of E-Coat.
Standing in a factory or a warehouse, you're bound to notice machinery, whether it's a conveyor system that winds across the floor or large fans that hang from the ceiling. You may even notice automated guided vehicles or autonomous mobile robots carrying parts, driving themselves from one section of the building to another. These machines are good candidates for using high-efficiency gearmotors, especially if they're expected to run for long stretches at a time. If they aren't using high-efficiency gearmotors, then they may be costing more money than they should.
They're like real fingers, able to pick up hard stuff, a spark plug or a metal pipe connector, and pick up soft stuff without breaking or smushing it: an egg, a loaf of bread, a donut.
KEB America announces the release of the new STEEL IT epoxy coating for servomotors. When motors are used in applications that are exposed to moisture and chemicals - such as food and beverage processing - they require special design considerations to ensure they will withstand the environment. The new STEEL IT epoxy coating option from KEB America provides a washdown servomotor with many of the benefits of a stainless-steel motor, but at a fraction of the cost.
