When shipping your machines around the world, or using a servo motor instead of standard AC, you typically need a different gearbox for each application. Not with the Varvel from DieQua. This video shows how the exact same worm speed reducer can accommodate NEMA, IEC and servo motors.
DRP+ Planetary Gearboxes are the dedicated solution to ZERO-BACKLASH rack & pinion and rotary table drive applications. Two planetary reducers mounted in parallel inside of super rigid universal housing. Two integral output pinions engage the rack to allow system preloading and maximize the stiffness on rack.
conveying system on the varnishing
line for a manufacturer of high-end
kitchen cabinets were leaking. Oil was
dripping on the cabinet parts — ruining
the finish. Why were half of the
gearboxes leaking?
Referencing a June 2014 Article, “High Gear Ratio
Epicyclic Drives Analysis,” by Dr. Alex Kapelevich:
I have designed a small compound epicyclic gearbox
with common planets.
Sun = 10 teeth
Planet = 14 teeth
Ring Gear stationary = 38 teeth
Ring gear output = 41 teeth profile shifted onto a 38
tooth pitch diameter.
Carriers are simply cages for the planet alignment
and location.
According to your article, and according to my
calculations and the prototype I have built, my inputto-
output ratio is a reduction of 65.6:1. I am using a ~
VG1 viscosity grease and Nylatron materials for the
gears and carriers.
