Bearing failures are a major concern in wind turbine main gearboxes. The risk of bearing failure F(t) is calculated from the bearing life L. If this is done for all bearings in a gearbox, then, the bearing subsystem reliability for the required life R(Hreq) = 1–F(Hreq) may be calculated. Methods used for such calculations for wind gearboxes are well established and have been widely used in other fields.
Andantex USA’s objective over the years has always remained the same: to provide innovative, high-quality gearboxes and solutions for use on industrial machinery. The Anglgear right angle drive is an example of our commitment to our customers’ needs and applications.
Join AGMA for our Gearbox CSI Course. This course will focus on forensic analysis of gear and bearing failures. It will be delivered live and online and a great way to complete your Advanced Gear Engineering Certificate from AGMA. If you are a ABMA member, this course is a great option for you. Please contact smialek@americanbearings.org to get a promo code to receive member pricing. to get a promo code to receive member pricing.
When precision machine drives are assembled without mounting pilots between the servo motor/gearbox and driven equipment, shaft misalignment becomes a key consideration in coupling selection. Learn more about the benefits of using a SCL servo disc coupling.
