The mobile machine market encompasses equipment supporting the movement of materials and components. This includes agricultural machinery, construction vehicles, municipal machinery, etc. These non-road mobile vehicles—tractors, cranes, forklifts and material handling equipment—often require personalized solutions focused on machine safety, automation and electrification. Manufacturers today are merely scratching the surface when designing electric drive equipment for these challenging environmental applications.
The complete Product News section from the March 2022 issue of Power Transmission Engineering, including the latest from Eaton Cummins, Schaeffler, Moog, GWJ Technology, Dana, SKF, Renewable Lubricants, Zero-Max, Bodine Electric, Hagglunds, Tolomatic and Isotech.
Lafert North America offers SITI Right Angle Worm Gearboxes in a variety of input and output mounting combinations and ratios from 5:1 to 100:1 for single stage reduction or 10000:1 for combination gearboxes. Hollow or solid output shaft in single or double design and stainless-steel output shafts are available.
These numerous pinion/planetary gearbox type combination options ensure that not only can a solution be found for a wide range of applications, but usually several, meaning that the torsional stiffness of the flanged gearboxes is greater than that of gearboxes with an output shaft.
With more models, sizes, and ratios, DieQua's spiral bevel gearboxes offer precision, performance and durability far above standard products. They're ideal for applications requiring high speed, precise motion control, high torque, or heavy shocks. Several configurations, options, and customized solutions provide unmatched design versatility.
