February 2, 2023
ZF’s Commercial Vehicle Solutions (CVS) division has further underlined its commitment to advancing ‘Next Generation Mobility’ by investing in cutting-edge 5G digital connectivity. Equipping its commercial vehicle test track at Jeversen, Germany, with its own powerful campus network enables enhanced testing of ‘Big Data’ backed solutions which are increasingly facilitating the next levels of Mobility as a Service (MaaS) and Transportation as a Service (TaaS).
Contact analysis can be used to calculate the transmission error and determine the profile modifications of a gear stage. In addition, a wide range of important gear-specific parameters can be calculated, such as tooth root stress, distribution of Hertzian pressure, oil film thickness, and many more.
After 33 years, over 1,500 educated attendees, and 68 facility tours the Helios team is excited to continue to help manufacturers build shops full of gear experts by hosting the 2023 Helios Gear School on May 16, 17, and 18 in Elgin, IL. The seminar course is designed for entry-level gear manufacturing personnel including manufacturing management, industrial engineers, supervisors, set-up technicians, operators, and quality control.
The Timken Company has reached an agreement to acquire Nadella Group, a leading European manufacturer of linear guides, telescopic rails, actuators and systems and other specialized industrial motion solutions, from ICG plc.
Heidenhain will be exhibiting at ATX West, Booth #4455, on February 7-9 in Anaheim, CA. Heidenhain will showcase the latest in absolute modular rotary encoders. ATX West focuses on how to better automate manufacturing processes by showcasing the latest automation and intelligent robotic technology to increase efficiency and reduce time, waste, and cost.
