GKN Sinter Metals is a developmental partner of the automotive industry producing the widest range of sintered drivetrain components from metal powder worldwide...
Stober Drives, Inc. is expanding its KSS stainless steel gearbox series by adding ratios that allow customers to use smaller reducers at lower speeds. The âKâ series is a right-angle, helical bevel gearbox...
NKE Austria offers rolling bearings for industrial gearboxes that meet the efficiency and reliability requirements of a wide range of sectors, such as general machinery, mining, material handling systems and heavy machinery...
Software company GWJ Technology, headquartered in Braunschweig, Germany introduces a completely new software generation of its TBK calculation software for gearboxes...
