Standard products rarely satisfy unique requirements. For right angle gearbox design challenges involving shaft configuration, precision, speed, environmental conditions, or extreme duty, no one can provide a special solution like DieQua can. By using our vast array of options, modifying standard designs, or creating complete specials, we’ll come through for you. As low as 1 piece in capacities from 1-300 HP.
Equipment downtime and reduced component
life are a few of the consequences — and
potential costs — of using the wrong seals on many types of industrial equipment including pump bearing frames, electric motors, fans, pillow blocks, gearboxes and more. However, if
correctly specified and installed, seals provide effective barriers that both retain lubricants as well as protect against water, corrosion, debris and other contaminants.
