Here at Precision Pump and Gear Works we offer emergency Gearbox service available 24/7, and have free pickup and delivery across the states. We rebuild gearboxes for the following industries: recycling, mining, marine, pharmaceutical, chemical, power plants, oil field, steel mills, and the food industries, plus more. Precision Pump and Gear Works does not shy away from a challenge in fact we welcome it; we will rebuild gears that are broken, chipped, or the teeth have been worn down over time.
The original fiber processing system called for a single flex, steel disc coupling to connect the motor to a gearbox. When operating the steel disc coupling did not allow enough parallel misalignment leading to premature bearing failure, oil leakage, and costly downtime. The solution was a custom designed, shortened Double Flex CD® Coupling from Zero-Max.
You can learn a lot by listening to the experts. That's why we have Revolutions on Power Transmission Engineering TV, where you can see our recorded interviews with some of the industry's leading suppliers.
Planetary Gearhead Technology with Meikel Quaas of Diequa
Precise and Rigid Gearboxes for Machine Tool Applications with David Regiec of Andantex
