The AWS-TF Series of bearings was designed expressly for wind turbine gearbox applications, achieving up to 7 times the life of standard bearings in hydrogen-charged environments. That means dramatically extended service intervals, increased efficiency and lower operating cost.
These numerous pinion/planetary gearbox type combination options ensure that not only can a solution be found for a wide range of applications, but usually several, meaning that the torsional stiffness of the flanged gearboxes is greater than that of gearboxes with an output shaft.
