Bonfiglioli recently inaugurated Bonfiglioli Academy at Chennai Institute of Technology, marking a new milestone in their journey of cutting-edge technological innovation. This collaboration with the institute is a powerful example of bringing academic expertise and industry leadership together. Bonfiglioli is confident that this partnership will redefine research and development and create an environment where theoretical knowledge meets practical application.
Gear backlash in precision applications is a critical element of gear system performance. Too much backlash can result in inefficiencies of motion in the gear train and will ultimately damage a gear’s teeth. Too little can mean the gears bind up and cause excessive wear to the tooth’s surface and the root of the gear, or even the fracturing of a tooth. Establishing and setting the appropriate amount of backlash is essential in gear design and manufacturing, according to Berg, a Regal Rexnord Brand.
After volume production of the CeTrax lite electric drive for light commercial vehicles started in April 2023, ZF has already produced its first thousand units. The ramp-up in volume production was steeper than planned because demand from the customer ISUZU increased. The drive is used by ISUZU to power the latest generation its light distributor truck, the ISUZU ELF EV. Further volume production is set to start imminently this year.
Compact and lightweight – such is the most common requirement for the gearboxes of emission-free, electric drives. With seven basic gearboxes, the LPI series by Liebherr fulfils exactly this need for high power density. With their low weight, reduced installation space and torque ranges from 20,000 Nm to 350,000 Nm, they are ideally suited as drives for crawler and crawler undercarriages. Customized large gearboxes are even available up to the maximum torque of 2,300,000 Nm.
Genuine Parts Company, a global distributor of automotive and industrial replacement parts, has announced that its board of directors has appointed James F. Howe to the position of president, Motion, the company's industrial business, effective April 1, 2024. With nearly three decades of dedicated service to the company, Howe brings a wealth of experience and expertise to his new role.
