NORD is pleased to announce new features to the myNORD online customer portal, including additional motor connectivity options, configurable CLINCHER.1 parallel shaft gear units, and updates to the user interface to make the tool even easier to use
Force Control Industries presents a maintenance-free, no-adjustment crane brake that virtually eliminates crane downtime as well as the need to perform maintenance and adjustment at height. The MagnaShear motor brake employs oil shear technology, providing longer service life in demanding applications like the frequent start/stop cycles seen on cranes, hoists, and winches.
Electric steel is used heavily in the manufacturing of electric motors. The material is key to producing the electromagnetic field used to turn the rotor. Without the electromagnetic properties associated with this iron alloy, the performance of electric motors would be substantially compromised. Historically, motors used in commercial and industrial applications have represented a major customer base for electric steel suppliers, and motor vendors have resultingly had little difficultly ensuring prioritized supply lines. However, the share of business held by commercial and industrial electric motor vendors is being threatened by the automotive sector in the wake of electric vehicles.
Print is not dead. While reading magazines cover-to-cover is a lost art—thanks to work responsibilities, 24-hour sports/entertainment coverage, and the universal time suck known as Instagram—someone, somewhere still prefers the printed word to the shiny, unfriendly artificial light of tablets and smartphones. This publication (hopefully) provides information engineers can discuss, debate, or collaborate on for future manufacturing endeavors. There would be no words, no photographs, no advertising without the paper used to print this very magazine.
How do gearbox and gear drive providers navigate the interesting challenges found in steel, cement, paper, and construction applications? Apparently, one application at a time. Thanks to condition monitoring technology, IoT solutions and the flexibility of engineering teams today, plant downtime is not as problematic as it has been in the past. The secret to success in heavy industrial markets comes down to staying ahead of component failures.
After receiving all the official approvals, Voith successfully completed the acquisition of the majority shares of Argo-Hytos Group on August 2, 2022. Argo-Hytos, based in Switzerland, develops and produces components for hydraulics and system solutions with a focus on the off-highway sector (agricultural tractors, construction equipment and material handling vehicles).
The Power Transmission Distributors Association (PTDA) will convene for the PTDA 2022 Industry Summit in Nashville, Tenn. on October 27-29, 2022. With more than 500 delegates in the power transmission/motion control (PT/MC) industry expected to attend, representing over 200 PTDA distributor and manufacturer companies, the Industry Summit—themed “Amp Up”—will offer cross-channel networking, shared learning and collaborative experiences.
