NORD DRIVESYSTEMS has announced the latest addition to their industrial gear unit family, MAXXDRIVE XD. These new, parallel shaft industrial gear units have extended center distances engineered specifically for reliable operation of cranes and hoists.
Steyr, a regional agricultural brand of CNH Industrial, has been awarded the 2022 Red Dot Design Award in the Design Concept category for its Hybrid Drivetrain Konzept – a hybrid diesel-electric drive system conceived to power lightweight, high-horsepower tractors.
SKF has developed a new hybrid deep groove ball bearing for high-speed applications. The new bearing is aimed at applications such as rail industry traction motors, as well as electric machines and drives. SKF already has three pilot customers, all of them OEMs.
The following article looks at the latest news on servo motors, drives and motors. How do we differentiate between the definitions? What can design engineers find between a stepper and a servo motor? Also, a quick update this summer on the benefits of closed-loop motor control.
David Brown Santasalo Australia recently completed a full strip and rebuild of a Zollern ZHP 4.33 Rope Winch Drum for valued mining industry partner, Zollern. The 7,550 kg Winch Drum powers a coal loader, with an output torque of 400 kNm (Stat Max) and an input torque of 893 Nm.
NORD is pleased to announce new features to the myNORD online customer portal, including additional motor connectivity options, configurable CLINCHER.1 parallel shaft gear units, and updates to the user interface to make the tool even easier to use
Force Control Industries presents a maintenance-free, no-adjustment crane brake that virtually eliminates crane downtime as well as the need to perform maintenance and adjustment at height. The MagnaShear motor brake employs oil shear technology, providing longer service life in demanding applications like the frequent start/stop cycles seen on cranes, hoists, and winches.
