The new version 3.50 of Softing Industrial's edgeConnector products is now compatible with ARM processors. This significantly expands the application possibilities.
Binder USA announced new angled variants of its snap-in 720 and NCC 770 series miniature connectors. A notable design change is the addition of a threaded ring between the contact body and the angled housing. This enables connectors to withstand loads that far exceed standard requirements, even when the force is applied at an angle to the connector axis.
With the unique combination of a sensor system and kinematics working independently in six degrees of freedom, the Smart Flex Effector compensation module gives industrial robots a sense of touch similar to that of a human hand. It thus allows the automation of processes that were previously difficult to manage or could only be performed manually. The innovation was honored at Hannover Messe with the Hermes Award 2023, the most prestigious international industry prize. The Smart Flex Effector increases the range of applications for robots because it sensitively compensates for tolerances in real time. Users can thus automate joining process, complicated assembly movements or difficult handling tasks. The compensation module can also be retrofitted in existing robotic applications.
Sensata utilizes Bosch Rexroth Smart Function Kit for mechatronic application
April 6, 2023
With its flexible multiproduct line for rotary encoders, Sensata has developed a sustainable solution. The heart of the precise sensor assembly system: The Smart Function Kit for pressing processes. The complete mechatronic package with preinstalled software reduces the programming to a minimum. Engineering, commissioning, and quality assurance become quicker, easier, and more cost-effective.
Festo introduces the company’s latest online productivity tool – Electric Motion Sizing – for error-free sizing of linear and rotary electromechanical systems. Electric Motion Sizing improves project efficiency by slashing the engineering time required for identifying and specifying harmonized electric motion systems. Multi-axis handling systems can be specified with Electric Motion Sizing’s sister productivity tool Handling Guide Online, which offers similar benefits.
On the occasion of the company's 75th anniversary, Faulhaber received a special honor by the municipality of Schönaich: From November 1, the street leading to the company site will be called Faulhaberstraße and the company building will bear the house number 1.
A high force Linear DC servomotor from Moticont has been added to their expanding line of voice coil or moving coil motors. The LVCM-095-038-01 Linear Voice Coil Motor is a true servo motor featuring zero cogging, high accuracy, and high repeatability when operated in a closed positioning loop
Intellidrives EtherNet/IP compatible Motion is a scalable and comprehensive solution that provides a common application interface and services for general purpose I/O and motion control that is fully compatible with standard Ethernet/IP topologies, minimizing integration effort with Ethernet/IP-based PLCs.
