Medical imaging equipment, water handling systems, conveyors, robotic systems and rotary and linear actuators are among the many devices that may be fitted with electric friction brakes to hold their loads in place when the power is off or disrupted.
When the need arises for linear motion
or positioning, there are many choices.
One can use an Acme screw, ball screw,
rack & pinion, or belts. The cost of a linear motor solution is generally greater than a mechanical linear product, but when one needs highly accurate, repeatable, high-speed motion, then the answer may be a linear motor.
Although David Korins had an impressive resume
of Broadway, film, television and music
credits, the New York-based production
designer had something to prove when interviewing
for the pop culture phenomenon
Hamilton. “I prepped for the interview like crazy, sketching
out my ideas, presenting a scene breakdown, basically
doing everything I could short of begging for the job,” Korins
said. “Lin Manuel Miranda (the show’s creator and star) had
developed an incredibly effective blueprint. I just wanted the
opportunity to help tell his story.”
In the world of PT components,
the clutch gets absolutely no recognition whatsoever. There are entire magazines dedicated to gears, bearings and motors, but clutches get very little press outside of the automotive industry.
