Just as we now consider rotary dial phones archaic, so are many installed synchronous belt drives. That they continue to operate is testimony to their durability. But that should not prevent you from taking advantage
of newer synchronous belt drive technology that can improve both equipment design and field installations.
During the past 10 years, the PM industry has put a lot of focus on how to make powder metal gears for automotive transmissions a reality. To reach this goal, several hurdles had to be overcome, such as fatigue data generation on gears, verification of calculation methods, production technology, materials development, heat treatment recipes, design development, and cost studies.
All of these advancements will be discussed, and a number of vehicles with powder metal gears in their
transmissions will be presented. How the transmissions have been redesigned in order to achieve the required stress levels while minimizing weight and inertia, thus increasing efficiency, will also be discussed.
rotary-type blowers? Examples: for motor KW; RPM; temperature; pressure production; lifetime; etc.
In other words, how do I choose between belts or couplings?
Some of us are old enough to
have had say, great-grandparents,
for example, who
when the occasion arose
would casually refer to cars
as “machines.” It sounded funny
and arcane, and we would snicker under
our breath. But of course the laugh
was on us; back in the day — 1910s
through the 1930s — automobiles were
commonly referred to as machines.
