I'm not able to get a good connection
between the pulley and shaft in my drive
assembly. Could you explain the various
ways of connecting a pulley to a shaft to
prevent the pulley from slipping?
Synchronous drives are especially well-suited for low-speed, high-torque applications. Their positive driving nature prevents potential slippage associated with V-belt drives, and even allows significantly greater torque carrying capability. Small pitch synchronous drives operating at speeds of 50 ft/min (0.25 m/s) or less are considered to be low-speed. Care should be taken in the drive selection process as stall and peak torques can sometimes be very high. While intermittent peak torques can often be carried by synchronous drives without special considerations, high cyclic peak torque loading should be carefully reviewed.
As with just about everything else
in the manufacturing world — and
all which that universe entails — it
depends. After all, that’s why the art
of manufacturing is a process — not
a one-system-fits-all discipline. Yes,
once that process has been properly
designed and correctly implemented
for a given manufacturing production
need, it may well run like the astest,
smoothest cookie-cutter-type operation
ever devised.
Dave Soma, the mechanical supervisor at Leland Olds Station, a coal-fired power
plant near Stanton, North Dakota, says he and his maintenance team care deeply
about keeping the plant running and providing people electricity, especially in the dead of winter.
If you’re replacing your belts more than once per year, it’s time to analyze your drive. From belt crimping damage to high belt installation tension to sprocket misalignment and adverse environmental conditions, this guide walks you through how to identify the reasons behind premature failure and makes recommendations on corrective and preventive measures.
