MPT Expo takes place October 15-17 at TCF CENTER (formerly the Cobo Center) in Detroit. Here are booth previews of some of the exhibitors most relevant to buyers of mechanical power transmission components.
In a research project at the Vienna University of Technology, the KISSsoft design software was used to check a new drivetrain concept and the micro-geometry of the bevel gear stage for a UAV (unmanned aerial vehicle).
For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
Rolling element bearings are widely used in mechanical transmission to reduce friction between two rotating parts. With the further development of the electrical motor in mechanical industry, REBs operate more and more at high rotational speed. For these applications, REBs power losses can
be predominant in mechanical transmissions.
