The Science Based Targets initiative (SBTi) has validated the Schaeffler Group’s targets for reducing greenhouse gas emissions as being in conformity with SBTi criteria and recommendations and hence in line with what the latest climate science considers necessary in order to meet the goals of the Paris Agreement. The global automotive and industrial supplier is committed to cutting its absolute Scope 1 and Scope 2 greenhouse gas emissions by 90 percent by 2030, with 2019 as its base year. The company has also set itself the target of reducing its absolute Scope 3 greenhouse gas emissions from purchased goods and services, fuel- and energy-related activities, and upstream transportation and distribution by 25 percent over the same period.
Bearing Specialists Association (BSA) and the Power Transmission Distributors Association (PTDA) announce the launch of the PIE Technology Platform (PIE), a cloud-based platform giving manufacturers and distributors of industrial products access to the most comprehensive catalog for the exchange of rich content product information.
Thomson Industries, Inc., a leading manufacturer of linear motion control solutions, has introduced a family of compact linear systems that makes it easier for motion designers to implement complex applications in small spaces. Designers needing thrust and bearing support in a single, compact unit now have the flexibility to build such applications with versatile, time-tested components from Thomson.
In the KISSsoft training program until summer 2023, you will find introductory training courses, advanced training courses and special training courses on selected topics.
Timken Utilizes LK Metrology for Bearing Inspection and Analysis
January 9, 2023
The Dudley, UK factory of The Timken Company supplies the engineered bearings it manufactures into a multitude of industries including mining, food and beverage, pulp and paper, cement, marine, and wastewater. Recently there has been a significant increase in demand for larger bearings up to 1,200 mm in diameter for use in the construction of wind turbines, which promises exponential growth in the coming years as countries across the globe work towards meeting their green energy targets.
The recently elected 2023 Board of Directors and Manufacturer Council of the Power Transmission Distributors Association (PTDA) begin their leadership terms.
The Timken Company recently announced its packaged wheel bearings are being used on Ford Motor Company's F-150 Lightning, the first mainstream electric light-duty pickup truck to hit the market. Timken bearings on the F-150 Lightning represent incremental content per vehicle, compared to its gasoline-powered counterpart.
Next-generation technology—everything from the electrification of vehicles to e-motors, bearings, mechatronics, and thermal management—was discussed during the Schaeffler Symposium 2022 in Detroit. I sat down with Jitesh Modi, director of engineering, during the event to discuss the “reinvention” of bearings for EV applications.
