Bega Special Tools introduces a portable multi-purpose induction heater on the North American market. The MF Quick-Heater 3.0-3.5 kW can be used for mounting, dismounting and pre-heating purposes. Weighing less than 8 kg and fitting in a small carrying case, this easy-to-use but powerful tool is just plugged into the mains 230 V. It can be used in difficult circumstances where other systems are impossible to operate, for instance where there is little space to work in or where no open fire is permitted. The heater’s flexible inductors are ideal for a large variety of parts with a maximum diameter of 120 mm. Application examples can be found in all types of industries.
Schaeffler recently displayed its automotive aftermarket solutions at the AAPEX show, hosted at the Venetian Expo in Las Vegas. Under the theme, “Your business is our focus,” Schaeffler hosted customers and industry partners at its booth, showcasing products and service solutions that enhance the vehicle’s life cycle, as well as technologies that support the transition to electric mobility.
A leading global copper producer has achieved exceptional results through the implementation of Vesconite Hilube wear-resistant bushings on load haul dump machines (LHDs). Departing from traditional bronze bushings, the mining company's adoption of Vesconite Hilube on Sandvik and Caterpillar LHD booms has led to an unprecedented increase in bushing lifespan, exceeding their initial expectations.
The Power Transmission Distributors Association (PTDA) has named Chris Bursack the 32nd recipient of its Warren Pike Award for lifetime achievement in the power transmission/motion control (PT/MC) industry. He received the accolade during the PTDA 2023 Industry Summit on October 20 in Amelia Island, FL.
The Timken Company has reached an agreement to acquire Engineered Solutions Group (a.k.a. Innovative Mechanical Solutions or iMECH), based in Houston, Texas. iMECH manufactures thrust bearings, radial bearings, specialty coatings and other components primarily used in the energy industry. The business employs approximately 70 people and projects revenue of approximately $30 million for calendar year 2023.
NKE Austria GmbH presents its bearings for railway applications. The bearings are used in traction motors and locomotive gearboxes as well as in railcars, trams and underground trains.
SKF has played its part in securing a new world record: the furthest distance travelled by a prototype motorcycle on a single tank of fuel. The prototype bike clocked up 4,183.8 km on its journey from Albino in northern Italy to North Cape in Norway – without needing to refuel. SKF helped motorcycle components supplier Acerbis in its AC50 project to design the two-wheeler.
VesArg, the Argentinian distributor of Vesconite, Vesconite Hilube and Vesconite Superlube low-friction bearing materials, is proud to announce the acceptance of the Vesconite Hilube needle-bearing kit for the Peugeot Partner and Citroen Berlingo, with VesArg having sold 500 kits for these vehicles in the last two years. This innovative solution addresses the recurring problem of suspension arm issues in these popular utility vehicles, which often require replacement needle-roller bearings.
More energy efficiency, higher performance and better controllability are the main reasons why more electric drive systems are being operated with frequency converters. However, these devices can cause high-frequency, asymmetrical interference currents, which, as a current passage through the output and fan-side bearings, can cause damage and premature failure.
Current-compensated CoolBlue toroidal cores made of Magnetec’s nanocrystalline material Nanoperm have proven to be effective protection against such conducted interference and its consequences. In addition, the Nanoperm Line Absorbers NaLA can also be used to significantly suppress symmetrical interference currents.
