Heat generation in bearings is manifested by the power losses of the transmission. Because of the rise in temperature due to heat generation, the appearance of dilatation adversely affects the bearings' geometrical characteristics.
Thrust cone bearings are an elegant option to handle the axial forces generated by the torque transmission in helical-toothed gear stages. They have proven as an efficient and reliable bearing concept for integrally geared compressors but are nearly unknown in other fields of gearbox engineering. The presented investigations consider three aspects which appear relevant to extend the field of possible applications for thrust cones towards gearboxes constructed with roller bearings.
Good machinery can last a lifetime. But, replacement parts for older equipment may be near impossible to find. So, what do you do when you're looking to replace hard-to-find bearings and related parts for older machines?
