The automotive industry is reshaping faster than ever before. Technology advancements are redefining transportation from traditional mechanics to complex sustainable, entertaining, and connected mobility enabled by electronics and software. To stay relevant in this fast-changing market, automakers must revisit how they approach all aspects of product design, development, and manufacturing.
Following is a presentation of a gear design based upon a theoretically perfect gear technology, for which an overview is offered for consideration. What follows is a report on the design's testing and subsequent manufacture of a hypoid gear pair for a 1999 Ford Mustang.
