Cortec Corporation recently announced its acquisition of Cortec Southeast Asia (CSEA) offices in Singapore. CSEA is now a wholly owned subsidiary of Cortec Corporation. This development promises to improve service and support to customers in Southeast Asia due to a direct connection with Cortec headquarters in Saint Paul, Minnesota.
Gasoline engines, pumps, generators and other machines operating in rugged environments require long-lasting components to ensure successful performance. Clutches designed with durable materials can prevent breakdowns, which would otherwise lead to expensive maintenance and downtime. One example of a ruggedized clutch — the Carlyle Johnson's EPC multiple disc electric pulley clutch — consists of a standard electromagnetic multiple disc design and utilizes oil shear to enhance service life.
The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
Optimal Engineering Systems, Inc. (OES) has released four new high resolution, high repeatability XY Alignment Stages. The AU200-120x120 Alignment Stages feature 120 mm (4.724 in.) of travel in both the X and Y axes. These new low profile 87 mm (3.425 in.) high XY stages, have a 188 mm x 188 mm (7.401 in. x 7.401 in.) open aperture. Easy integration of tooling and fixtures is facilitated through a precision series of threaded mounting holes.
Siemens Digital Industries Software announced that the Luna Rossa Prada Pirelli America's Cup team is using the Siemens Xcelerator portfolio of software and services to design, simulate and optimize its racing yacht for the forthcoming America’s Cup challenge (37th America’s Cup).
On Wednesday, November 16 and Thursday, November 17, the Reggio Emilia’s plant of Kohler Engines sponsored and hosted the event "Alternative Fuels. A sustainable path to engines decarbonization", a workshop organized by SAE-NA, STEMS-CNR and Kohler.
DENSO, a leading mobility supplier, has increased efficiencies, improved employee morale and ergonomics, and managed a tight labor market by deploying six MiR250 autonomous mobile robots to transport materials in its 800,000 square foot powertrain component production facility in Athens, Tennessee.
To determine whether a machine screw jack or ball screw jack is the right fit for your application, Thomson and Motion engineers offer the following application parameters early in the design phase.
