Implementing a power-on-demand concept based on variable speed drives allows for energy saving in any application
that involves pumps or hydraulic systems. And when used in combination with an intelligent wiring and communication system, relevant machine data can also be easily recorded
- the basis for comprehensive power management.
Beginning with this initial installment , and with the gracious permission of ABB/Baldor Electric, we are
pleased to announce the beginning of a new series -- Baldor Basics: Motors. This is a collection of basicsdriven,
motor-intensive articles authored by former Baldor engineer Edward Cowern, PE, a respected
name by many in the electric motor industry. During his tenure at Baldor, Cowern - now enjoying his
retirement - was tasked with producing a number of motor- and basics-related tutorials, primarily in
response to a steady flow of customer questions regarding motors. Today's customers continue to ask
questions and seek answers to address their various motor-related issues. As with Cowern's original
introduction to the series, we hope you find these articles useful and would appreciate any comments or
thoughts you might have for future improvements, corrections or topics.
life in this application.
Mechanical guiding systems, such as crossedroller bearings, work well for most motion control applications; however, when precision, angular repeatability, and geometric performance
(runout, straightness) are critical or
where submicron bearing rumble is problematic, air bearings are recommended. An air-bearing stage is a rotary or linear positioner that floats on a cushion of air, using one of several preload mechanisms, nearly
eliminating mechanical contact and thus wear, friction, and hysteresis effects. Here are eight reasons why an air-bearing stage might be the right choice for your application:
Synchronous drives are especially well-suited for low-speed, high-torque applications. Their positive driving nature prevents potential slippage associated with V-belt drives, and even allows significantly greater torque carrying capability. Small pitch synchronous drives operating at speeds of 50 ft/min (0.25 m/s) or less are considered to be low-speed. Care should be taken in the drive selection process as stall and peak torques can sometimes be very high. While intermittent peak torques can often be carried by synchronous drives without special considerations, high cyclic peak torque loading should be carefully reviewed.
The average travel time to
work in the United States is
25.4 minutes, according to
the U.S. Census Bureau. This
number is probably low if you factor in
a traffic accident in New York City, light
rain in Chicago or it's simply Tuesday
in Los Angeles. It's safe to say 25.4
turns into 45 minutes in many areas
of the country at seven o'clock in the
morning.
