Thrust cone bearings are an elegant option to handle the axial forces generated by the torque transmission in helical-toothed gear stages. They have proven as an efficient and reliable bearing concept for integrally geared compressors but are nearly unknown in other fields of gearbox engineering. The presented investigations consider three aspects which appear relevant to extend the field of possible applications for thrust cones towards gearboxes constructed with roller bearings.
The load carrying capacity of gear transmissions depends strongly on design, material and operation conditions. Modern analysis methods, e.g. finite element analysis (FEA), consider the above parameters with more or less sufficient accuracy. Yet it remains an ongoing challenge to account for backlash and manufacturing errors, despite a definite need to do so.
As manufacturers continually search for ways to cut costs and increase ROI, machine monitoring and predictive maintenance (PdM) solutions are an increasingly cost-effective way for plants and factories to help reduce process downtime.
Good machinery can last a lifetime. But, replacement parts for older equipment may be near impossible to find. So, what do you do when you're looking to replace hard-to-find bearings and related parts for older machines?
If you can find that magic bullet that will reduce the machining process, you can achieve
meaningful efficiency gains. It is imperative that check-weighers or in-motion weighing
systems remain both accurate and efficient while attaining a consistently smooth operation
because they dynamically weigh products as they move across the belt.
It is hard these days to find any device that is not IoT-compatible or WiFi-connected. I recently had a new well pump installed that requires an iPhone for setup, which makes it hard for me to check or change the setup since I do not own an iPhone. In Olden Times, you had potentiometers or RS-232 connections - and that was fine.
