The theme of this issue is integration. Mechanical components are being developed with embedded sensors. The components are talking to each other, sending information to the cloud and producing terabytes of big data to help manufacturers better understand their processes, predict problems and control costs.
Different motor types favor different application areas. No single style has advantages in all application spaces. Direct drive applications favor hybrid servos while high-speed, geared down applications tend to favor the conventional servo motors.
With the increasing mechanical power capacity of gearboxes, the thermal power limit tends to become the limiting factor. To achieve a balanced system, the gear unit needs extra cooling. Using a fan that is mounted to a fast rotating shaft is a common solution. For this solution an optimal design is investigated.
