For a maintenance crew, it is important to know which bearings need re-lubrication and make sure they are lubricating those bearings. The bearings can be lubricated manually or by automatic lubrication systems. This article
will review each method and discover its pros and cons.
Modern aircraft, missiles and space vehicles employ a large number of electric motors and actuators. While the basic design of these motors is in many respects very similar to that of their automotive and industrial counterparts, motors for aerospace applications differ significantly in some areas.
Chain and sprocket drives of one form or another have been driving machines and
conveying materials for over a thousand years. The chain manufacturing industry has developed numerous types and sizes of drive chains. Although it is a mature form of power transmission, there are still many industrial applications for which drive chain is suited. It is economical, resistant to shock loads, easy to install, has the ability to transmit high torque, operates in hostile environments, and is efficient. Chain and sprocket drives are highly engineered and manufactured within close tolerances.
Yes, the headline is correct: Autonomous vehicles are not a new idea. In fact, in the 1950s, handsfree driving so interested General Motors engineers that
they designed a concept car for it. And in 1956, at its own auto show, the GM Motorama, the automaker unveiled the car, the Firebird II.
