Involute splines are commonly used in gearboxes to connect gears and shafts, especially when high torque is transmitted through the coupling. The load is shared among multiple teeth around the coupling circumference, resulting in higher load capacity than a conventional single key. However, the total load is not equally shared among all spline teeth, mainly because of
pitch deviations resulting from the manufacturing process. The load distribution along the spline engagement length is also nonuniform
because of tooth misalignments and shaft torsional effects. This paper presents an investigation of the influence of spur gear loads on the load distribution of spline teeth.
When software goes bad, what do we call it? System failure? Human failure? A virus? A number of words will work. How about this? Glitch. It has that onomatopoeic quality that fairly screams, Downtime! And with good reason -- software-generated miscalculations can have very expensive -- if not perilous -- repercussions.
Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
Mounted ball bearings are everywhere in industrial applications. They serve critical roles in keeping a manufacturing operation running smoothly and in ensuring that equipment functions properly and reliably. So why might it be advisable to spend significantly more for a dimensionally
comparable bearing from one supplier versus another?
This article describes a series of tests that can be performed by the average user, with little experience, and without sophisticated measuring instruments, to quickly determine the most important performance characteristics of linear motion systems.
For the most accurate measurements,
miniature and instrument ball bearing
dimensions should be measured with a
calibrated air gauge. A good second option is a calibrated optical comparator. On occasion, it may be necessary to use a calibrated, hand-held micrometer to double-check a measurement or for simple verification while working in the field.
