In its largest order to date, Danish wind turbine test specialist R&D Test Systems will develop the 30 MW powertrain and gearbox test bench for ZF Wind Power’s future “Test & Prototype Center” at Lommel, Belgium. Capable of simulating the multiplicity of wind loads that a nacelle powertrain might experience in its lifetime, the test rig, to be delivered in 2024, will help improve product reliability and shorten time to market.
Company offers high performance components and materials
August 29, 2022
Wind farms are expanding around the world. This is good for climate change. Wind turbines are being installed on the high seas with nacelle heights of more than 100 meters and rotor diameters of nearly 170 meters. This increases both the electricity yield and economic efficiency. Freudenberg is aiding wind power’s conquest with high performance components and materials.
ONYX Insight examines how digital tools can provide wind energy solutions, from day-to-day problem solving to future-proofing operations and maintenance (O&M) strategies through condition monitoring technologies.
One of ONYX’s customers and a leader in driving up the reliability and asset performance of the wind industry, Pattern Energy, uses ONYX turbine monitoring for over 1,100 wind turbines. Across this fleet ONYX connects several CMS hardware types to fleetMONITOR, a multi-brand solution for drivetrain monitoring. Two of the wind farms were retrofitted with ecoCMS in 2018, the technology with which ONYX disrupted the CMS industry.
Mainshaft bearings inside wind turbines are subjected to extremely harsh operating conditions that result in failure patterns which include surface-initiated fatigue, abrasive wear and uneven internal load distribution. This webinar will introduce you to the latest engineering advancements in spherical roller bearing design, including solutions that allow potentially damaging thrust to be safely transferred through the bearing to the housing support. The resulting reduction in torque, friction and heat significantly improves the overall efficiency of the system, thereby enabling the wind turbine to generate more power – more reliably!
