Electric and fluid power has expanded the focus recently at the Motion + Power Technology Expo - September 14-16, St. Louis, Missouri - but gear manufacturing remains the core of AGMA's biennial trade show.
Mainshaft bearings inside wind turbines are subjected to extremely harsh operating conditions that result in failure patterns which include surface-initiated fatigue, abrasive wear and uneven internal load distribution. This webinar will introduce you to the latest engineering advancements in spherical roller bearing design, including solutions that allow potentially damaging thrust to be safely transferred through the bearing to the housing support. The resulting reduction in torque, friction and heat significantly improves the overall efficiency of the system, thereby enabling the wind turbine to generate more power – more reliably!
Wind is a form of solar energy.
Winds are caused by the uneven heating
of the atmosphere by the sun, the
irregularities of the earth’s surface, and rotation of the earth. Wind Turbines
convert the kinetic energy in wind into
mechanical power.
