Here’s what we know about Tremont, Illinois: It’s a small village in Tazewell County, (population 2,400+), holds an annual summer turkey festival
(quite popular) and the courthouse is a famous historic site where politician James Shields challenged an “up-and-coming” lawyer named Abraham Lincoln to a duel with cavalry broad swords (they showed up, but the duel never materialized). In 2016, you can add FIRST Robotics Competition World Champion to the village’s rather eccentric list of accomplishments.
Moving around in open space
is a cautious endeavor. Without
the luxury of gravity, the slightest push can send you twirling in circles or, worse, tumbling off into the unknown.
Every motion must be thought out and
deliberate, all the more so because our bodies take that luxury into account.
Behind a thick sheet of unblemished
glass that stretches from wall-to-wall, ceilingto- floor at Delta Gear, just south of a shop lined with ultramodern grinding machines whirring away, is Scott Sakuta’s aquarium.
