The DMC-3x01x Motion Controller Series is Galil's latest generation single-axis motion controller. It uses a 32-bit RISC processor to provide higher speed than older models. Like all Galil controllers, programming the DMC-3x01x is simplified with two-letter, intuitive commands and a full set of software tools for servo tuning and analysis.
Compact drives with an extended power range offer users simple commissioning and operation, plus integrated safety.
January 3, 2023
Siemens is extending its Sinamics G120C-series of drives to include three new frame sizes for high power output ranges. The new frame sizes cover the power output range from 22 to 132 kilowatts (kW), making the series available from 0.55 kW to 132 kW. Standard features of the series include a compact design with optional filter, long cable lengths, full integration into the Totally Integrated Automation (TIA) Portal and simple control and commissioning.
CES, the world’s most influential tech event, is back in Las Vegas on Jan. 5-8. With more to see than ever, the show footprint will be over 70 percent larger than CES 2022.
Bosch Rexroth has opened a new customer innovation center near Austin, Texas. The facility will provide a unique technology development experience for Bosch Rexroth factory automation customers from multiple industry segments, including electric vehicle manufacturing, battery production, consumer packaged goods and semiconductor manufacturing. The new innovation center is the latest in a series of expansions and investments Bosch Rexroth is making in North America, including a new plant in Queretaro, Mexico, and an expansion of its operations in Charlotte, N.C.
Offering a track with stronger magnets for their linear motors than previously available, ETEL introduces the new MWD+. This magnet-track family is compatible with any existing LMG and LMS linear motor from ETEL, enabling up to 15 percent higher continuous and peak forces compared to the existing MWD product.
Optimal Engineering Systems, Inc. (OES) has released four new high resolution, high repeatability XY Alignment Stages. The AU200-120x120 Alignment Stages feature 120 mm (4.724 in.) of travel in both the X and Y axes. These new low profile 87 mm (3.425 in.) high XY stages, have a 188 mm x 188 mm (7.401 in. x 7.401 in.) open aperture. Easy integration of tooling and fixtures is facilitated through a precision series of threaded mounting holes.
At the beginning of this year, the automotive and industrial supplier Schaeffler acquired Melior Motion GmbH, an innovative manufacturer of precision gearboxes for robotics and automation applications, among others. As of December 1, 2022, Melior Motion GmbH will operate under the name of Schaeffler Ultra Precision Drives GmbH. The aim of the acquisition is to continuously expand the Industrial division’s portfolio of precision gearboxes and to secure a strategically strong position in the dynamically growing market for industrial automation.
SMAC Moving Coil Actuators recently introduced its new LPL Series 125 low-profile electric linear actuator designed specifically for use on robot end effectors.
