If you’re an electrical engineer
you know how an electric motor works; if
you aren’t, it can be extremely
confusing. Therefore, here’s the simplified explanation (or the “how
an electric motor works for dummies” version) of how a four-pole, three-phase
AC induction motor works in a car.
One of the best things about
being a journalist — whether
for example it be reporting on
manufacturing, politics, show business, or anything else — is being paid to “go to school” and learning about any number of things that you were perhaps ignorant of at the outset.
For a 5-megawatt wind turbine prototype,
aerodyn employs the latest control and software technologies, including a comprehensive PC-based control solution and the new modular TwinCAT Wind Framework. The TwinCAT Wind Framework features the latest software engineering and Big Data applications to extend current Industry 4.0 concepts to the wind energy industry. The modular software supports, for example, the direct provision of sensor data to the operator’s database, and in general enables the easy adaption of the wind turbine operation management to future requirements.
