Thomson Industries, Inc., a leading manufacturer of linear motion control solutions, has introduced a family of compact linear systems that makes it easier for motion designers to implement complex applications in small spaces. Designers needing thrust and bearing support in a single, compact unit now have the flexibility to build such applications with versatile, time-tested components from Thomson.
Intellidrives EtherNet/IP compatible Motion is a scalable and comprehensive solution that provides a common application interface and services for general purpose I/O and motion control that is fully compatible with standard Ethernet/IP topologies, minimizing integration effort with Ethernet/IP-based PLCs.
Heidenhain will be exhibiting at Photonics West, Booth #3053, on January 28-February 2 in San Francisco, Calif. Heidenhain will showcase the latest MULTI Degrees-of-Freedom (MULTI-DOF) motion control components, offering manufacturers a better way to implement metrology designs. Photonics West is the world’s premier lasers, biomedical optics and optoelectronics event.
Compact drives with an extended power range offer users simple commissioning and operation, plus integrated safety.
January 3, 2023
Siemens is extending its Sinamics G120C-series of drives to include three new frame sizes for high power output ranges. The new frame sizes cover the power output range from 22 to 132 kilowatts (kW), making the series available from 0.55 kW to 132 kW. Standard features of the series include a compact design with optional filter, long cable lengths, full integration into the Totally Integrated Automation (TIA) Portal and simple control and commissioning.
CES, the world’s most influential tech event, is back in Las Vegas on Jan. 5-8. With more to see than ever, the show footprint will be over 70 percent larger than CES 2022.
