Behind a thick sheet of unblemished
glass that stretches from wall-to-wall, ceilingto- floor at Delta Gear, just south of a shop lined with ultramodern grinding machines whirring away, is Scott Sakuta’s aquarium.
It seems preposterous in the whimsical, wireless world of today, but in 1977 cinema’s greatest visioneers came together and decided the pinnacle of robotic technology in the future would be a motorized trash can.
At the recently held annual meeting of the Bearing Specialists Association, there was a lot of talk about online sales channels and how Internet retailers are changing the way industrial products are researched, sourced and purchased.
