The availability of high-strength shaft materials, in combination with bearings with high carrying capacity, allows use of slimmer shafts. However, the modulus of elasticity remains the same, so seat
design for bearings and gears must be given close attention.
Compact loaders are employed where large machines have no access or are over dimensioned. New hydrostatic drives from ZF meet the demanding needs of this market.
Motion control systems engineers work chiefly in two well-defined areas: 1) new designs and 2) redesigns or retrofits. This article examines the best approach for each option.
Next time you are strolling across a manufacturing plant, check out the hardware on the ground. Shop floors are nothing but cables plugged into machines, cables plugged into computers, cables plugged into other cables...
