Hannover Messe 2023 presents the ideal networking hub. This is where AI developers, software engineers get together with users to jointly develop industrial-grade AI products or processes. Whereas in the past, the focus was on use cases in which errors or anomalies were detected or prognostications were made, industry in 2023 is focusing on the optimization of processes and the use of AI methods for simulation, testing and product development.
The Timken Company has acquired the assets of American Roller Bearing Company (ARB), a North Carolina-based manufacturer of industrial bearings. ARB's offerings join Timken's industry-leading portfolio of engineered bearing solutions. ARB, which boasts a large U.S. installed base and strong aftermarket business, generated sales of more than $30 million in 2022.
Commercial garage doors range in many sizes and configurations requiring a “just right” model and size brake for reliable automatic operation. Depending on the design and size of the overhead door and placement of the brake, a variety of brake models and sizes offer solutions from the Miki Pulley brake lineup.
February 2, 2023
Contact analysis can be used to calculate the transmission error and determine the profile modifications of a gear stage. In addition, a wide range of important gear-specific parameters can be calculated, such as tooth root stress, distribution of Hertzian pressure, oil film thickness, and many more.
